Jensen 500w $60
125 x 2 @ 4 rms
500w bridged @4 rms
kicker 300.2 $60
75 x 2 @ 4 rms
300 bridged @4 rms
xtant 121m $110
1 x 125 @ 4 Ohms
1 x 250 @ 2 Ohms
Freq response : 5Hz to 50 kHz
THD:
S/n ratio : >100db
Damping factor : >200 (@100 Hz into 4 Ohm load)
Fuse: 1 x 30
dimensions : 11" x 1.8" x 8 "
infinity reference (1 broken mount hole) $70
111 watts RMS x 4 at 4 ohms (139 watts x 4 at 2 ohms)
278 watts RMS x 2 bridged output at 4 ohms (4-ohm stable in bridged mode)
bass knobs $5
sony 2 channel exm 302 $15
30 x2 @ 4 rms
90 bridged @4 rms
mtx thunder 704x $40
70 watts RMS x 4 at 4 ohms (105 watts x 4 at 2 ohms)
210 watts RMS x 2 bridged at 4 ohms
All working, see photo for cosmetic.
above
Actual cost. Most can go via flat rate box but will not be responsible for damage if sent this way(thin box and tight fit so not much room for padding), would advise parcel post as I have more space to pack
postcalc.usps.gov my zip is 94952
Jensen 500w $60
125 x 2 @ 4 rms
500w bridged @4 rms
kicker 300.2 $60
75 x 2 @ 4 rms
300 bridged @4 rms
xtant 121m $110
1 x 125 @ 4 Ohms
1 x 250 @ 2 Ohms
THD:
S/n ratio : >100db
Fuse: 1 x 30
bass knobs $5
30 x2 @ 4 rms
90 bridged @4 rms
above
