JDM Honda with glass panels and Sundown bottom end
i have a ******* questhave neverion, but i fiberglasssesd so, how do you get the finished panel to stay on the door?
its screwed to the panel through the speaker holes.
Looks phenominal
In this instance they are screwed from the door panel to the pod, that way the panel tightens up to the door better. I did learn on this build that I will glass some pan head bolts into the pod next time and then bolt the pod to the door, making it real tight.
and thanks alot for the props, much appreciated
wouldnt the outside of the panel vibrate from not being screwed into anything? almost like flapping from the midbass. i love learning about fiberglass stuff as i wanna try it this summer lol
the drivers are secured to the pod is secured to the panel and the panel is secured to the door, so there is no part that is unsecured, infact if you are not careful and you warp the glass while laying it up you will have a hell of a time getting the panel on once the pod is secured to the panel because the pod is so rigid from having so many different planes/curves.
I hope that helps
I hope that helps
okat i get it now lol. i just thought you screwed it in and called it a day. like with one layer in like 3 spots haha.
kmanian
kmanian
Grand Cayman
psychoacoustics
slater
    Oct 4, 2025
    Oct 4, 2025
