jchargu3 10+ year member
CLICK THE TINY PICS TO MAKE THEM BIGGER!!!!!!!!!!!!!!
Last year I bought 2 - DD1508's from OXSIGN, he's a good friend and fellow truck club member and trust his every word on audio so I knew I was getting good stuff.
I came up with a plan.. The box will be under the rear seat, fastened to the cab with a special locking mechanism that im putting together..
Amps and wiring go behind the seat backrest, but this truck only has a fold up seat bottom so I had to modify it to work to where the backrest folded down as well... Simple.
Originally I was also going to mount my Whelen strobe box in the interior but decided against it due to space and I don't want a lot of stuff behind the seat, just whats needed to run the audio.
Originally I was going to run an Elemental Nine.1 and an elemental Nine.2, I got the nine.1 and got things setup then ran out of money because my job started getting slower so I just kept it as it was for a year....
NOW IM RESURRECTING THE BUILD
To make adjusting and checking things easier, I'll be installing 2 - white leds on either side of the wall to shine on the amp adjustments.
I still need to do the big three upgrade, this may happen on sunday.
On to the build up stuff.
On 9/24/08
I got the particle board to make the "rack" That weekend I cut it, and covered it in grey material, then started installing.
I had gotten an old, no good Optima yellow top that I traded in at pepboys for a BRAND NEW one no charge, and got it installed pretty quickly.
9/28/2008
Amp on the back wall (mine was test fitting/uncovered yet)
Amp rack removed
On 9/24/08
9/28/2008
Amp rack removed
