JBL W15GTi MKII T/S Parameters?
Audio Junkies
I've checked everywhere and can't find the T/S parameters for the JBL W15GTi MKII, just very basic specs.
I can find the MKI parameters in the online manual though, and WinISD also has them.
Is the MKII the same driver as the MKI with a different appearance?
I'll be calling JBL Monday to find out for sure, but I figured one of the Team JBL guys/gals on here might know.
Thanks ahead of time.
Thanks Colin. You were right, specs are exactly the same as the MKI.
THIELE-SMALL PARAMETERS
VOICE COIL DC RESISTANCE: REVC (OHMS)* . . . . . 2.95
VOICE COIL INDUCTANCE @ 1 KHZ: LEVC (MH)* . . . . . . 1.06
DRIVER RADIATING AREA: SD (FT2) . . . . . . . . 0.839
SD (M2) . . . . . . . . 0.078
MOTOR FORCE FACTOR: BL ™* . . . . . . . 15.39
COMPLIANCE VOLUME: VAS (FT3) . . . . . . . . 4.67
VAS (LITERS) . . . . 132.20
SUSPENSION COMPLIANCE: CMS (μM/N) . . . . 153.02
MOVING MASS, AIR LOAD: MMS (GRAMS). . . . 260.67
MOVING MASS, DIAPHRAGM: MMD (GRAMS) . . . 248.15
FREE-AIR RESONANCE: FS (HZ) . . . . . . . . 25.20
MECHANICAL Q: QMS . . . . . . . . . . . 7.20
ELECTRICAL Q: QES . . . . . . . . . . . . 0.51
TOTAL Q: QTS . . . . . . . . . . . . 0.48
MAGNETIC-GAP HEIGHT: HAG (IN) . . . . . . . . . 1.00
HAG (MM) . . . . . . . 25.40
VOICE-COIL HEIGHT: HVC (IN) . . . . . . . . . 2.60
HVC (MM) . . . . . . . 66.04
MAXIMUM EXCURSION: XMAX (IN) . . . . . . . . 0.80
(ONE-WAY LINEAR) XMAX (MM) . . . . . . 20.32
Audio Junkies
Audio Junkies
Tampa
Audio Junkies
    Jun 24, 2026
    Jun 24, 2026
