it probably does... but it doesn't mean it's loud!!! higher watts doesn't mean louder...Originally posted by Killa sin i have the jbl 1200.1 amp and the guy at sound advicce says that my amp ***** and he tested it and it was only about 700 watts? is this true? also, can the 1200.1 power a 12w7 good?
700 watts? He probably tested it at 4 ohms...Originally posted by Killa sin i have the jbl 1200.1 amp and the guy at sound advicce says that my amp ***** and he tested it and it was only about 700 watts? is this true? also, can the 1200.1 power a 12w7 good?
prove it...Originally posted by jjoven1225 it probably does... but it doesn't mean it's loud!!! higher watts doesn't mean louder...
Send 100w rms to a sub, and then send it 200rms...you doubled the output of your amp...in theory that would mean a 3 db increase.Originally posted by jjoven1225 it probably does... but it doesn't mean it's loud!!! higher watts doesn't mean louder...
you didn't defend youself....you just showed how doubling source power, doubles output (3 bd increase = double the output)....did you change your mind?Originally posted by ss3079 Send 100w rms to a sub, and then send it 200rms...you doubled the output of your amp...in theory that would mean a 3 db increase.
- Steve
what? i didnt understand what you just said //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gifOriginally posted by evo2k3 you didn't defend youself....you just showed how doubling source power, doubles output (3 bd increase = double the output)....did you change your mind?
yea i got that but it sounded like he was dissin steve or that steve did a bad job defending himself or somethingOriginally posted by snova031 He said generally speaking if you double the wattage output, you get a 3 dB gain, which means more watts=louder
double the wattage=double the output=3db INCREASE=louder.Originally posted by evo2k3 you didn't defend youself....you just showed how doubling source power, doubles output (3 bd increase = double the output)....did you change your mind?
which one do you think will get louder???Originally posted by GSteg double the wattage=double the output=3db INCREASE=louder.
now lets refer back to:
"it probably does... but it doesn't mean it's loud!!! higher watts doesn't mean louder..."
more power=more output= "x" dB INCREASE=louder.
so how could it not get louder with more watts (providing the woofer can handle the power)//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
eerr..whats the point of this?//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gifOriginally posted by jjoven1225 Amplifiers that are mass marketed through large electronics
supermarkets, and mail order catalogues are designed to make
their manufactures and dealers money, not to necessarily sound
good. In this market price is what sells product, and the reason
for that is simple enough. If your product sits on a shelf in a
mass merchants store next to 4 or 5 other products just like it,
what is going to make the customer choose yours? What you print
on the box. Since there are no qualified salespeople to help you
choose the right one, you are left to read each box carefully and
decide. The combination of what you read and the asking price
are the determining factors. A crappy amp and a decent amp are
rarely sold in the same place and here is an example of why. A
crappy amp and a decent amp both sit on a shelf side by side.
Both amps are the same physical size. The crappy amp has the
following specs printed on the box:
200WATTS X 200WATTS MAX POWER Frequency Response 20-20K
Not more than .7% total harmonic distortion @ 1 watt both
channels driven. REGULAR EVERYDAY LOW PRICE $179.00 NOW
$99.95 with 90 day warranty.
The decent amp has the following specs printed on the box:
40WATTS X 40WATTS RMS From 20 - 20K @ .07% THD. $249.00
Now judging from this information you would choose the crappy
amp. It has more power (way more power) and cost less, plus it's
on sale. FRED fell into this trap too, and so do about 500
people every day just in this city. The truth is that the bottom
amp, the decent one, is FAR better than the crappy amp. It has
FAR more power, and the difference in sound quality cannot even
be compared. How can this be you wonder? Both manufactures have
listed specifications for their amplifiers that are within the
boundaries of the law. One has stretched it to the limits of the
law, and one has slightly under rated theirs. This is the
difference between the two types of amplifiers. It is easy to
see why the better of the two products are not sold in mass
merchandise marts, and why the others are not sold in specialty
shops. A simple guideline to remember is the "DOLLAR PER WATT"
theory. A decent amplifier should cost MORE than one dollar per
watt. If you find an amplifier like the one in the sample above,
that is less than a dollar per watt, don't buy it. The sample
above calculates out to 25 cents per watt. The irony of this is
that the second amp is actually LESS money per watt than the
first. If you take the REAL watts that each puts out the figures
are like this: First amp total REAL watts is 50. That's $2.00
per watt. The second amp total REAL watts is 160. That's a
$1.55 per watt.
http://www.decware.com/secrets4.htm
we're talking about REAL world watts (test benched), not advertised watts. if the pyramid amp puts out REAL watts, and say an Arc audio amp puts out 60 REAL watts, then the pyramid amp would be louder, PERIOD.Originally posted by jjoven1225 which one do you think will get louder???
http://www.millionbuy.com/pyrpb781x.html
or
http://www.speakersound.com/index.html?loadfile=catalog181_0.html
i know im exagerating here, but just to prove a point... you'll understand more when you get more experience with car audio..
