JBL GTI MKII 12"
Text me with any questions...
714-290-1243
Alex
Thank you for your interest !
10/10 LOOKS AND WORKS LIKE BRAND NEW
The W12GTi MKII has 700 watts RMS and peak power handling of 4000 watts. It has a die-cast vented basket and vented polepieces to enhance the cooling of the voice coil and motor structure. The subwoofer’s thermal capabilities are exceptional, boosting power handling. Play long and loud.
The JBL® Differential Drive® Design is a huge advancement in subwoofer motor technology. It enables the subwoofer to use two 3-inch diameter, 6-ohm voice coils instead of a single coil. You can’t see all the things we do. But you will hear and feel the significantly higher power handling.
Proprietary Kevlar®-impregnated woofer cones are strong, yet lightweight, which means the subwoofer can handle the high power you want and high-pressure you inflict on it. A nitrile-butylene rubber one-piece surround delivers the optimal blend of elasticity and internal damping.
$179 each
Based off zip...
JBL GTI MKII 12"
714-290-1243
Alex
$179 each
Based off zip...
