Jbl bpx2200.1
shiipseki
JBL BPX2200.1
New only taken out to test 9.5/10
550 Shipped
Power Series 2-Channel Class D Car Amplifier • 2450W x 1 chan. @ 4 ohms • 450W x 2 chan. @ 4 ohms • 1810W x 1 chan. @ 1 ohm • Max power output: 2940 watts x 1 chan. • Dynamic Bass Optimization • Two channels can also be connected in parallel
Still...lol I just really don't understand audio prices lol just like jl products jbl is solid very nice stuff but not even close to worth what they are "valued" at they are nice if you get a steal of a deal other than that I don't touch stuff like Sundown, JL, JBL, Skar and so on.
But glws I know its a nice amp
Good luck finding 2500 at 4 ohms clean and underrated for less money.
yeah but basically ANY sub that is dual coil can be dropped below 4 ohms...so its not needed really its a nice option but not that many high power single coil woofers these days..
with that said bump for seller...glws
The main reason for someone to have this amp is to be easy on their electrical. I had the bpx1100.1 on a stock 80a alt and size 51 starting batt(Almost as small as a motorcycle battery) and never dropped below 13.2.
Why not just post all the specs you have for the amp including power rating and size of amp.
RMS Power Rating:
4 ohms: 2450 watts x 1 chan.
4 ohms: 650 watts x 2 chan.
1 ohm: 1810 watts x 1 chan.
Remote bass level input (remote level control sold separately)
LED operation mode, power, and protection indicators
Dynamic Bass Optimization (DBO) - This provides variable filtering with adjustable "Q" below 100Hz, far beyond conventional "Bass Q" circuits, by allowing the low-frequency output to be optimized for specific subwoofer applications.
Two channels can also be connected in parallel - that's right, parallel - to provide double the current of single channel into impedance below 2 ohms
Preamp RCA outputs
DC, short circuit, overheat, and overload protection circuitry
Heavy duty aluminum alloy heatsink
Gold-plated RCA level inputs
Gold-plated screw terminals
Variable high-pass filter (32-320 Hz, with selectable 12/24 dB/octave)
Variable low-pass filter (32-320 Hz, with selectable 12/24 dB/octave)
CEA-2006 compliant amplifier
Frequency response: 22-302 Hz
Dimensions: 21"L x 12-1/4"W x 2-9/16"H
4-gauge power and ground leads recommended.
great amp
rare line made in cohoots with Crown.....swwwweeeeet stuff, high end for sure. Would love to have played with a pair of these or one of those gti big boys. very efficient stuff.
shiipseki
shiipseki
LA, CA
shiipseki
