SOLD JBL BPX 500.1 800rms @4, JBL P1024 Sub, Sterero Integrity BM CHEAP!
mike11202
DE
Selling some car audio stuff thats been sitting around. Priced very low to sell.
1) I have 2 JBL/Crown BPX 500.1's Brand NEW Re-certified, 780rms @4 ohm Birthsheet (1 to 4ohm stable 760rms @1 ohm). I currently run one myself, definitely most efficient amp best sounding amp I ever used, puts no strain on my electrical system. You'll be amazed when you see the results.
$140 + shipping
2) Like new JBL P1024 Subwoofer, Plus One Technology.. has close to the cone area of a 12", great subwoofer, I prefer this over the old 10" Type R I used, it sounds better and is a bit louder.
$60 + shipping
3) SI BM 12", one tinsel lead snapped, easily fixable, still powers and runs on the other coils with good output
SOLD
nope this is a subwoofer amp
# Frequency Response: 25.4-340 Hz
# Signal to Noise Ratio: 66.4 dB
# High-Efficiency Switching Power Supply
# Current Servo Circuitry with Crown Technology
# "Direct Connect" Terminal Block Allows for 4 or 8 Gauge Power Wire
# Series or Parallel Bridge for Full Power Into 4-Ohm or 1-Ohm Loads
# Die-Cast Aluminum Chassis with Top Plexiglas Viewing Window
# Variable Low-Pass Crossover (32-320 Hz)
I didn't see where there was a difference (didn't see a "light" or "lite" version). That said, if you can fit it, then the JBL BassPro SL 2 would...
WANTED JBL 800GTI
Slava Ukraini, Brother! Don't have that amp but good luck and welcome!
I don't think this is ideal, but let's assume you can easily mount all the tweeters. That installing them is going to be really simple, and...
13
Working with undersized material, adjusting on the fly, testing before setting; you sound like and old pro. You are as meticulous as alot of the...
76
5K
mike11202
mike11202
DE
mike11202
audiobaun
    May 19, 2024
    May 19, 2024
