JBL A3000GTI Amp
Mikey53591
JBL A6000GTI Amp
Item(s) for Sale:JBL A3000GTI Amp
Item(s) Description/Condition: Condition: Lightly Used by previous owner
Was passed down from a previous employee of JBL, barely used it. In great condition and when last tested, was in working condition.
Spec List:
2-channel car amplifier
1670 watts RMS x 2 at 4 ohms (1670 watts RMS x 2 at 2 ohms)
3129 watts RMS x 1 in bridged mode (1-ohm stable in bridged mode)
internal neon lighting (one 20" and two 6" neon tubes)
variable high-pass and low-pass filters (32-320 Hz) — switchable 12/24 dB per octave
Dynamic Bass Optimization: variable filtering with adjustable "Q" below 100Hz allows output to be optimized for specific subwoofer applications
variable phase adjustment (0 to 180 degrees)
preamp-level inputs and outputs
CEA-2006 compliant
fuse rating: 300A x 1
1/0-gauge power and ground leads recommended — wiring and hardware not included with amplifier
wired dash-mount remote control adjusts bass level
23"W x 21-1/2"H x 6-1/2"D
Price: $1400 OBO
Won't be on the forums much, so feel free to contact me by these means:
E-Mail: Mikey53591@gmail.com
Phone (Call/Text): 920-253-7141
I wish people would realize that they know very little compared to what they don't know and would wisely decide not to comment about stuff way over there head..I hope that amp goes to a good home
I didn't see where there was a difference (didn't see a "light" or "lite" version). That said, if you can fit it, then the JBL BassPro SL 2 would...
WANTED JBL 800GTI
Slava Ukraini, Brother! Don't have that amp but good luck and welcome!
I don't think this is ideal, but let's assume you can easily mount all the tweeters. That installing them is going to be really simple, and...
13
Working with undersized material, adjusting on the fly, testing before setting; you sound like and old pro. You are as meticulous as alot of the...
76
5K
Mikey53591
Mikey53591
Wisconsin
disturbed471985
    May 16, 2024
    May 16, 2024
