Ive Got A Few Questions
darkdrake
Darkness is me
ok ive got a great system in my car. but lately its been draining power like crazy. so heres my question.
if i wanted to add another battery to my car what all would i have to do?
how would the battery stay charged?
how much time is required in this type of install?
ill post more here as i think of some....
thanks for the help.
you would need some wire a 2nd batt. and a isolator.
you would hook the battery to the other battery or straight to the alternator
it will only take however long it takes you to pull the wires.
hope that helps some
If you wire a second battery to your existing one in parallel, you basically now have the electrical equivalent of a single large battery with double the amp-hour rating (the reserve capacity to drive a load for a period of time).
It is a larger strain on your alternator, though...but as long as it's not a 60A model or so, you should be fine //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
what i was wanting to do was buy a yellowtop for under the hood and hookup my system and accs to a marine (deepcycle) battery in the back
is this possible without crapping my alternator and i think its 120 amp i beleive...
1. You'd need a fuse anywhere it passes through metal, so yes //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
2. Parallel wiring is wiring the positive of the new battery to the positive of the existing one, and doing the same for the negatives...series wiring would be running the positive of one to the negative of the other, which doubles the voltage (= not a good thing in this case).
darkdrake
Darkness is me
darkdrake
Fleburg,Ky
darkdrake
