It's just not very loud.
AL210
PA
Just installed a sub woofer setup in my son's Jetta.
10 inch Alpine type S in a sealed box located in the trunk.
Amp = Hifonics Zeus ZRX1200.1D
The sub coils are wired in parallel for 2 ohms. Checked with DMM and reads 2.1ohms.
Voltage at amp doesn't drop below 14 volts. It just doesn't seem loud for 600 watts RMS. I thought this would be a good setup for him and the trunk would help add to the bass. //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
How are the gains set? And you really can't expect too much out of a single 10 in a sealed box. That amp doesn't do rated power either, but it should still do alright.
Signal to the amp is from the RCA sub woofer output on his Pioneer AVH-X2500BT.
I know this isn't correct but we started at 0 output from the Pioneer and slowly turned the gain up on the amp. Had to turn the gain on the amp all the way up. Ended up backing it off a bit and setting the Pioneer up to +4.
That could be part of the problem. I'd consider getting a line driver or swapping out the head unit to get higher preout voltage.
A single sealed lower line 10 isnt going to get very loud in a trunk.
Would it be beneficial to change to a ported box? I saw some refurbished Kicker 12 inch solo baric L5 in a ported enclosure for good a price. Any thoughts on them? I heard they hit really hard.
Yes a ported box would make it louder. An l5 12 in a ported box should be louder than the type s 10.
No. Stay away from Kicker subs unless it's a Solo X
And a ported box is beneficial, but only if built correctly. Almost no prefabricated boxes are worth a crap, though.
AL210
AL210
PA
BrownVanMan
michigan born
    May 14, 2026
michigan born
    May 14, 2026
