Issues from the front page
  • 4
pro-rabbit
Moderator
12,639
OKC, OK
Any time I to access my profile/PMs or any other option from the front page, I am unable to follow the link it will take me back to the front page.
Now I can click on "forum" then I have access to everything with out issues. It's not a big deal, but I just thought I would point that out. It does this on 4 of my computers(1 at work and 3 at home) and my phone.
Ok this is fixed now. We did an upgrade a couple days ago and a few issues arose, as usual.
i have (or did as of like an hour ago) a problem signing in from the front page. i get a 404. if i click 'forum' it works fine tho.
Be sure to see the sub specs. It should tell you the ideal sealed enclosure size.
686
Twist both grounds together. Good call on checking power with a multimeter. I assume you have pulled out and re-inserted the fuses, so as a quick...
Are your tweeters amplified or powered by the radio or maybe factory amp? I'd check your wiring for sure, make sure 12v power and ground are...
pro-rabbit
Moderator
pro-rabbit
OKC, OK
ChevyRidinLow
