is xmax everything
You are comparing two subs with largely different surface areas, contrary to the 15 vs 15 implication. That is hardly a good comparison of excursion as it relates to output.
Just sayin.
They may have different surface areas, but the L7's still get pwned by other circular subs of near the same price range.
Ok, well let me change subs here. I just brought up the L7 because we were talking about L7s here.
I had an HD3 after the XXX and the HD3 made the XXX sound wimpy. (Although the XXX sounded much, much better //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif)
That's better. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
whats the xmax of a l7 and the surface area doesnt make up for the xmax or yea
so a sub with the same power handling and in ideal box with more xmax than l7 its a toss up in everyday listening as which one is louder
IMO it's better to try the subs out in the real world that judging them off what a sheet of paper says. There's more to a sub than its cone area and xmax.
And there's also more to a sub than what it hits on a meter... //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
When going ported, the majority of the pressure comes from the port. So with that said, do you really think Xmax from the sub is the most important factor? Maybe what you should be trying to do is create a box with very good port speed (rounded off corners, flared ports, etc.)
king ranch
Banned
king ranch
fl
BEAVER.989
ThxOne
    May 13, 2026
ThxOne
    May 13, 2026
