Is this wiring possible????
trigga_b
shitty boss and a sony here's the specs.
BOSS- Amplifier Type: Mono
RMS Power @ 4 Ohms: 400W x 1 @ 4 Ohms
THD at 4-Ohm RMS Power: 0.01 %
Bridged RMS Power @ 4 Ohms: 600W x 1 @ 2 Ohms
Speaker Level Inputs: yes
Preamp Outputs : yes
Built-In Crossovers: LP
Bass Boost: 0 - 18 dB
Frequency Response: 20-20,000 Hz
Signal to Noise Ratio: 102 dB
Fuse Rating: n/a
SONY-200 watts RMS x 2 at 4 ohms
250 watts RMS x 2 at 2 ohms
500 watts RMS x 1 at 4 ohms
stereo or bridged mono output
Tri-way capable (Tri-Way Crossover required)
CEA-2006 compliant
requires 4-gauge power and ground leads Â? wiring and hardware not included with amplifier
MOSFET power and output stages
preamp- and speaker-level inputs
preamp outputs
gold-plated connectors
variable low-pass crossover (50-300 Hz, 12 dB/octave)
variable bass boost (0-10 dB at 40 Hz)
15-3/4"W x 2-3/16"H x 10-
Possible ? Yeah just a matter of connecting wires. Should it be done ? Not with my amps you won't . Looks like a fantastic plan to release the magic smoke from a couple amplifiers //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
how do you bridge a mono amp?
Very, very carefully. It requires hot glue, and lots of popsicle brand popsicle sticks. And sprinkle of sunshine thrown in //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Do not do that.
Your amplifiers will not reproduce the song you are playing at the same exact point in time. Running each VC off of two amps is even worse than running a single DVC sub on two different channels.
Run one sub on its own amp, bridged channel or get a new amp.
Fuse Rating: n/a
CEA-2006 compliant
preamp outputs
ya something is whack w/ those BOSS specs...
u may wanna look into some better and also matching amps if you really want to enjoy your L7s...
the reason i thougt of this is because that boss amps cuts off in like 5 ****ing mins, cuz its hot...so i was just going to use it as a "loud button" and run the 2 channel amp to each sub. The mono amp was going to be hooked into my subwoofer output on my hu, which i have a button to cut the sub output on/off. I guess ill just leave it like it is until I get that kicker amp
trigga_b
trigga_b
chicago
trigga_b
Mike Mccabe
