Is this normal?
argenis69
SQ Bass Lover
844
NY, USA
Hi Guys,
A few days ago I went to fix my rear window and when I opened the trunk to start working on it, I noticed that both batteries and the subwoofer were covered with cold frost. //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
Is this something normal? Is there something I have to do to avoid this?
Do I have to worry about it?
Thank you.
There is absolutely nothing you can do about this.
If the day before there was high humidity and the night was very cold, the moisture in the air will freeze and fall on surfaces. This is commonly called "frost".
Anybody who leaves their car outside instead of in a garage will have that happen to them this time of year.
No it's not bad for your equipment. Unless you have your amps circuit board all out in the open with no casing. lol
If the day before there was high humidity and the night was very cold' date=' the moisture in the air will freeze and fall on surfaces. This is commonly called "frost".
No it's not bad for your equipment. Unless you have your amps circuit board all out in the open with no casing. lol[/quote']
Thanks, thats a relief. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
argenis69
SQ Bass Lover
argenis69
NY, USA
argenis69
Brendon Jenness
    May 8, 2024
    May 8, 2024
