Is this how you tune?
RollinRemz05
Im making a box thats 2.25 cu ft. I saw the box builds in these forums for the 2.25 cu ft @ 31 Hz. Thats the exact box i want but in different dimensions. Do i just have to put the same ammount on square inches in port into the box i want to build to get it to tune the same? Thanks!
Yehh just build it to whatever you can than just ask someone on here and they'll point you to a calculator or tell you themselves....if their in a good mood
But if the box is smaller than what you had wanted and you have the same port it should tune it lower and same as other way bigger and should be higher if that makes sense
RollinRemz05
RollinRemz05
Toms River, NJ
Skip01
michigan born
    May 14, 2026
michigan born
    May 14, 2026
