is this enough bracing?
taintedplay
dallas
ok subs will be 4 15inch re se's off of a aq3500d
1. one threaded rod down the middle, is that enough?
2. ill have a flushmount baffle(as shown) but is two sheets plus the beauty panel ontop needed?
3. also, i only have room to mount the aq on the box, if i have that side double thick mdf plus rubber grommits, is that enough to stop vibration/flexing?
Its not the amount the subs weighs that determines bracing!The MM of 4 15's at 45hz is alot and at resonance the box can flex tremendcily.The bracing is to stop this not support the weight of the subs.
id rather be safe than sorry, and since my amp is going to be on the box i really want to be safe. heres what i think ill do. 1x1 board run around like i showed, does it matter what type of wood?
then allthread down the middle, and between each sub. then on the wall with the amps, have it double layered
Yup. That is the bread truck that Richard Clark built for MTX many years ago . 60 inch subwoofer. The problem was that the truck wasn’t...
14
I will still find the blame..Bad tool, cheap connectors, junk wire..LOL 🤣 🤣 I didnt have enough B12 this morning is my favorite
23
Like OP stated, there are radios with higher power output. Most radios have around 18 watts RMS per channel. They mostly claim 50w per channel but...
18
4K
taintedplay
taintedplay
dallas
Trixter
    May 20, 2024
    May 20, 2024
