is this enough bracing?
taintedplay
ok subs will be 4 15inch re se's off of a aq3500d
1. one threaded rod down the middle, is that enough?
2. ill have a flushmount baffle(as shown) but is two sheets plus the beauty panel ontop needed?
3. also, i only have room to mount the aq on the box, if i have that side double thick mdf plus rubber grommits, is that enough to stop vibration/flexing?
id rather be safe than sorry, and since my amp is going to be on the box i really want to be safe. heres what i think ill do. 1x1 board run around like i showed, does it matter what type of wood?
then allthread down the middle, and between each sub. then on the wall with the amps, have it double layered
taintedplay
taintedplay
dallas
Trixter
