Is this box too big for my Kicker L7's?
b52ravens
23
CT
I started building a box today for my dual kicker 12's. I'm not really sure if its too big but here are the specs
3/4 MDF
Dimensions (W x H x D): 38" x 14" x 26"
11-3/16" Square Cutouts
6" Wide Port
Slot-Port Tuned @ 34Hz
5.0ft^3 TOTAL Net Volume
That seems about right, but you can actually go bigger if you want. Assuming you port is the correct length, you're going to have 5.15ft^3 after its displacement. The volume is actually going to be a little less than 5ft^3 after sub displacement and any bracing you may be using(or should be using). I wouldn't go much larger unless you're planning on using less than rated power for them.
phew, okay thanks a lot man lol. the box seemed really big when i was building it so i wanted to check if it was TOO big. and what do ya mean bracing?
hmm, that actually isn't near as big as optimum size. 4.5 per sub, if i remember correctly. and, what do you mean 6" wide port? how tall/deep? shoot for 60-65"^2 port area..
4.5ft^3 per sub? Maybe if he's using just a couple hundred watts per sub. Using rated power there's really no reason to go over 3ft^3 each.
i'm going off memory without my cheat sheets, 6'^3 per 15..... ok, i just did some digging around, and stand corrected...... 3.25net each for the 12, and it does make a difference...... does anyone know where i can buy an oral foot-removal tool. this tastes bad now, lol
You need something more like a pro audio woofer. You want a really light Mms with a lower Fs. Idk how much loudness vs range you want, but a...
14
411
760
601
I have been attempting to study the true nature of why we tend to tune transmission lines and enclosures in general like we do, the nature of...
b52ravens
b52ravens
CT
akheathen
    May 16, 2024
    May 16, 2024
