Is This box portable?
fishkilla67
Nope, that box is WAY too small to be ported. When you port a box, that takes away from the enclosure volume. Plus, a ported enclosure usually must be a higher volume than a sealed enclosure anyway. So, the enclosure must be of higher volume to begin with and #2 the overall size is increased even more by port volume.
He probably means that it works well as a sealed enclosure when using polyfill. Polyfill makes the sub perform as if it is in a larger enclosure. 0.25 cubic foot is a very small enclosure even for a sealed enclosure - there's no way to pull it off if you port it. The port will take up space, that will decrease the volume even more. By the time you port it (with a small aeroport), you're probably looking at a 0.20 cubic foot or less. No way.
"1. Carried or moved with ease: a portable typewriter; a portable generator.
2. Capable of being transferred from one employer to another. Used of an employee benefit."-dictionary.com-portable
//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif You tell me:D
Alright, I won't port it then.
Yes, I realise .25 cu ft is small to begin with, but then again, so is the Miata.
Trunk subs sound like crap too, so this is about my only option.
Thanks guys.
fishkilla67
fishkilla67
Des Moines, Iowa
fishkilla67
