of course you can, it'll just clipThe 1000. You can always turn it down. You can't turn it up
Yes. That's a good amp. On par with kicker and rockford but can be found a lot cheaper.The alpine 1000 one?
You clearly aren't listening. If you want the RF so badly just go get and make the mistake. There is a reason that all this other info is being PMd to you instead of posted in response on here. If I were you, buy the brown van man amp listed above. Will power perfectly, does the right power @ 2ohm.This is the diagram I received in a pm. I was told it would work by wiring it parallel at 2 ohms. Subwoofer Wiring Diagrams, One 4 ohm Dual Voice Coil (DVC) Speaker
