akheathen
Premium Member
trianoacitol contraceptiv
first, use a headlight, or resistors to limit the current when you power it up. next, use a battery to take care of the voltage drops, and smooth out the power some. what is happening, is that the amp is trying to power up, but the charger voltage is dropping too low for it do operate, so the power supply shuts of, and then activates again when the voltage is back above about 10. really, the idle current alone on this amp should be 2-3amps, and turn-on spike is probably anywhere from 5-15a, depending how far the voltage drops. have you alrady ohmed the legs on all the output and ps transitors?
o.p.- you can order from digikey, and they have all the info sheets, etc with them. the bottom numbers are the build code/date, which will show on the spec pdf. something like 35 p = year/month week, or month/year line, or similar combinations. what you will find is that the digikey, and other part numbers will have more preffix/suffix and different variations. look at the manufacturer part number. current available parts are pretty much going to have a pbf, or something on them that indicates "lead-free", which you will see on the list if you pay attention. stick to a good brand, if not the same. those would be 2stc4467 and 2st1694 in st micro parts. you can check mouser, etc, but just googling will get you a list of suppliers. the parts are becoming obsolete, but there are some replacement parts for them, i think mouser has a cross-reference.
