Chicago_one
Background: I picked up this sub/amp/box combo on Craigslist pretty cheap. Yeah, yeah, you get what you pay for... so I took a chance. Owner assumed everything "Still worked".
12" Infinity Kappa, Kenwood KAC-7201 2 Channel, Q Logic Box. The amp already was missing the 2 30A fuses (can take that as a hint, something already went wrong in the past).
I installed everything with a StingPro 1 farad cap w/digital display and 2 new 30A fuses: I turn the car on, amp doesn't light up but the fan seemed to turn, cap activates and lights up. I shut everything down, hook up the sub, try again, turn on the radio and the fuses immediately blow.
So yesterday, I open up the amp bc I typically figure, if fuses blow as soon as power is put to them, theres an internal problem... right? I'm by no means a pro when it comes to internal issues, so I took pictures of what I thought looked odd. Can you help me out? I figure the white junk is no bueno... please help me elaborate and maybe I can fix this amp.
EDIT*** I can't post pics yet bc I'm new I guess.
So I'm finding a lot of white putty like substance around the little capacitors (I believe thats what those are) Seems to be oozing from the base of them. I can't see any crack or opening, but it surrounds the base on 3 of them. 2 are right near the ground/power terminals on the motherboard. One is near the center of the amp. Additionally, there are a few black, greasy areas on the backside of a couple resistors. If you think you can help, I can message you the pics, and hopefully be allowed to embed them in this post soon. Sorry for the hassle. ***
Let me know what you think from these photos. Like I said, I'm not a pro with issue like this at all, but I'd like to learn. Is there an obvious fix? Is this typical? Or should I toss this to the scrap yard and buy something else?
Luckily, that Infinity Kappa did test at 4.1 ohms on my DMM so I figure that's still good.
