Is there THAT much benefit from multiple wire runs?
Supergumby5000
Project: F350 begins...
Say for a 4krms setup, is there really any huge benefit running 4 runs of 1/0 vs 2 runs of 1/0? The only thing im really improving on is resistance issues correct?
Reason i ask is i've been using Knu fleks in my truck (great to work with), but for the price of 2 runs of fleks from my under the hood battery to my bigger batteries in the back, i could do 4 runs of KLMX and still save money. I dont need flexibility for those runs anyways.
I really wish I had a comparison before/after I did all of my runs to see the benifit //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
Are you planning on going directly back to the front with your ground run(s) as well (linking the front and rear batteries negatives)? I would do that if youre going all out. But 4 runs of klmx I would think would be an advantage over 1 or 2 runs of flex, especially if you can do it for cheaper
Correct, everything is battery-to-battery.
You will not have a noticeable difference.
Is it better? Yes
Did I do it? Yes, b/c I got 200feet of kicker hyperflex for $300
The thing is, if you have 2 or more rear batteries, most of your current will be drawn from the rear batteries, hardly any will be drawn from the front... and when it is... 2 runs of 1/0 will handle more than enough of the current.
Now, if you're upgrading, and always adding more power... then go for it. If you're running dual alternators, go for it. If you're trying to win world finals, and need that last .1dB, then go for it. But with exactly what you have now, daily driving there will not be a noticeable difference.
nG
Is it better? Yes
nG
//content.invisioncic.com/y282845/emoticons/thumbsup.gif.3287b36ca96645a13a43aff531f37f02.gif thanks.
Is it better? Yes
nG
x24
Supergumby5000
Supergumby5000
Pullman, WA
UpGradde
Mike Mccabe
