alwaysontop
i dont get it i have a box tuned right and big enough for two subs but can i really put two subs in it?
do you have it open right now? if so, i can walk you through itactually i just cant figure out the port length at all. i cant figure out how the hell to use winisd i dont know what half of it means
^^^^^you didnt i understand that all i have to remember is just subtract half of the width from the port length. now i have one more question.
the only reason you subtracted that was because the port is on the left or right side and the subs on the other so it would kinda look like this
| | O O |
yes, as long as a port uses 1 side of the enclosure, you have to include end correction
if i do my box like that the volume for one sub is 2.3 cubes.
do i multiply that by two to get the total volume i need for 2 subs or do i just keep it at 2.3 cubes?
if you are going to use two subs, and each one requires 2.3 cubes (or if thats what you're aiming for) then you need a box that will be 4.6 cubes after all displacements (4.6 cubes net, not gross)
correct.so 4.6 cubes after driver displacement and bracing right?
