is the MRP m1000 too much for two 12" cvr kickers?
b52ravens
23
CT
im considering buying these kickers to go with my amp but i saw that they were 400 watts each RMS and the amp pushes out 1000 watts at 2 ohms. my amp blew my last arc audio subs which were supposed to be both around the same range. im the type of guy that likes to listen to my sub loud and to push the subs. would the amp blow the kickers?
If you have the proper enclosure and know how to correctly set your gains (as in no clipping), the subs will be fine. However, you need to make sure they are dual 2ohm or single 4ohm each to correctly wire them for that amplifier.
b52ravens
b52ravens
CT
09civic
