is my math right
spljim
IL
I tried the calculator from carstereo.com and came up wuth this I wont 1.25cf at 35Hz and this is what I came up with External measurements are 36" wide 11.5" tall and 14.5" deep the first port pece the opping of the port is 10.25"long the back one is 27.5 and the last one is 9.5 and the port is 3.5" wide with 35 in of port the Minimum Usable Vent Area is 35.15 inches that is what the calculator sead is this ok to bild or can you help me fix it
dude your post is way to confusing...
Without knowing the port displacement (im sure I could figure it up, but it would take forever with your description) sub displacement, and really an accurate discription of the box, this would be impossible to figure out.
You need...
Sub displacement in Cu. Feet.
Port displacement in Cu. Feet.
Port Area in Sq. Inches
Box Volume in Cu. Feet.
Port Length in In.
Chevyaudio my sub is a Oz audio Me 10.2 and to keep it short I wont at lest 30" of port tund to 35Hz for sql if this is to mutch just tell me the box cant be biger then 36" 11.5" 18" forget what I posted what can you do with this
spljim
spljim
IL
rpfuror
