Is My Head Unit Fried?
  • 2
SerPandy
Hey guys, couldn't really find anything online for this so I figured I'd make an account here and see if anyone can help.
So I purchased a Pioneer head unit for my 98' Dodge Dakota a while back and wired it up myself and everything worked fine. Occasionally when it rained/got really cold the unit would turn off and on again and I had no clue what was causing it, but just recently when I was getting into my truck to drive somewhere, the stereo just flat out refused to turn on. I took the bezel trim and pulled out the radio but while I was pulling it out, the yellow wire from the head unit connector(which is the 12v memory, if I remember correctly) was pulled out. The wire and the metal connector at the end(not sure what it's called, but the pic attached looks just like it) all came out and make a small spark. I put the wire back where it went and ever since the stereo has not turned on.
Did I fry my head unit? I unplugged the connector that plugs into the head unit and tested the power wire and it is getting power from the truck but nothing beyond the connector. I checked the fuse on the unit as well as the ones in the truck and none of them are blown so I'm not sure if it's just a weird connection or if I killed my unit. Any help would be great, thanks!
a spark would be an issue if the memory pin touched the head unit chassis.  not only would that likely blow a fuse but it would also put 12V on the HU chassis, which can damage internal circuits.  it matters what it sparked against.
if the pin is not fully inserted in the harness, it won't make contact with the HU pins, and the HU won't turn on.  likewise, if the pin opening is too big, it might not make contact with the HU pin.
confirm you're measuring voltage at the harness between the yellow (+12V) and black (gnd) wires. you'll have to measure from the back of the harness because the HU side has openings that are too small for a DMM probe.
63
515
There are a couple of options. You can use a marine bt unit. They come in the size of a hockey puck and can mount anywhere. This is the marine unit.
610
There are bluetooth amplifiers. You can just use your phone or an I Pod as the music source and not touch the radio.
741
SerPandy
SerPandy
keep_hope_alive
    May 12, 2024
Brendon Jenness
    May 11, 2024
