is my amp dead
caliece
hi i turned on my amp today and i heard a pop when i turned the volume up then i went to go look at the amp and it was in protect mode. thhis is driving me crazy.//content.invisioncic.com/y282845/emoticons/mad.gif.c18f003ab0ef8a0d9c27ca78d77a6392.gif
where did the pop come from the amp or sub, disconnect the speaker(s) and see if it still does it
i set everything right it was playing weeks ago no prob but today it just stop working it is a lightning audio 4 channel amp.
well that would explain the pop lol, j/k check all your connections and make sure everything is tight and connected, sometimes if you got massive amps as the one listed above the tremendous output of the subs will vibrate the connections loose, lmao but check everything just to make sure
caliece
caliece
chicago il
Raisedin305
Mike Mccabe
