Is it safe to tap into the power wire for my deck to run a police scanner?
In IL it is not illegal to have a scanner. You should determine how many watts/amps the scanner is rated for. Looking up the model specs online should give this info. This will allow you to determine if you can splice into an existing power wire or if you'll have to run a new one.
Also keep in mind that if you run RCAs/amps, you could possibly induce ground loop noise if you ground the scanner poorly.
if it does draw a lot of power and needs its own dedicated power wire you can always use a relay to hook it up to an ignition fuse so it's still only on when the car is...
There aren't many wires coming off the amp. There's: power in (12V Batt +, usually the big red one), power out (Ground, usually the big black...
959
Hello, I am getting ready to install my 3000 watt taramps and 2 15s in an expedition. I am a little hung up because my old car had a 220 amp...
Cant use the scope because the amp is plug and play. Can only set it up by ear. Will I hurt the speakers by playing a 1000hz tone at 75% volume...
Glock23
Glock23
il
bubbagumper6
Brendon Jenness
    May 8, 2024
    May 8, 2024
