Is it possible to fix this?
bennettjt
VA
I recently bought a 15" audioque SDC2.5 subwoofer.
I put it on my 2500.1 JUST to test it at a low volume to make sure everything is working fine. It must've gotten a tad too much power because it sounds like I blew the sub. I push the cone down and it sounds like a soda can is being crushed. The bottom spider looks like it came unglued from the center white piece. Is this fixable with some sort of glue, or am I going to have to completely recone it?
I attached a pic, it's hard to see because it's difficult to take a picture in the small gap
(the black cone is like 1/4 inch above that black glue line where it was suppose to be)
You might be able to get a speaker shop to realign the coil and glue the spider back if you didnt screw it up too much. Otherwise, full recone.
ALSO, DO NOT attempt the repair yourself. If the coil isnt aligned right and you glue it again you might as well pay for a recone. My local guy would fix that for 25 bucks if its possible so look around you. Might be able to find someone.
bennettjt
bennettjt
VA
SPLaudio
