is it possible a battery can read 12volts but...
x2 i was having the same problem with my girls acura after i installed an amp and sub, the terminals were always corroded, if you twist the connectors on the post, you can sometimes find a sweet spot because it grinded away some of the corrosion, go to napa or schucks and buy some anti-corrosion spray, shit sprays out purple, and use a wirebrush and scrape the inside of the connectors and scrape the terminals, corrosion causes a barrier between the metals so the car doesnt start
you dont need to buy that spray...just get a cup of water and put a ton of baking soda in it and set the terminals in the cup for a lil bit
Etac
Angry Bunny Killer
Etac
Jersey
Bender.
