is it ok to fiberglass over great stuff foam?
Nope no toxic fumes or chemical reactions. YOu may experience a little melting of the foam depending on how hot your resin mix is. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
You may rip a hole in the space/time continuum. //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
He said laying glass over foam, not dividing by zero.....//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
He was referring to someone calling this site helpful for car audio I believe.
Of course not bro, I'm having my car transported to you for install.. You are the only person I would let touch my car on the planet.. Should be...
16
4K
No reason you couldn't just glue a ring of plywood up under there then paint it with some bedliner or plasti-dip or similar to keep the elements...
Yeah, these are listed as 3ohms nominal and that is why you see the 2.7ohm rating (where they can drop to). There are a number of things wrong...
923
i would recommend placing an amplifier on these to serve any justice at all https://www.polkaudio.com/en/product/mm1-series/mm6502...
marcotheclepto
marcotheclepto
United States
marcotheclepto
    May 16, 2024
    May 16, 2024
