talon2nr7588
if you leave your battery on the ground will it discharge faster. i was told that it gounds it.
learn something new everydayjust look it up on google.
johnson controls (a battery maker) said this was a case of coincidence. the problem used to come because the material was very sensitive and easily damaged. the problem would happen because when you set it on the concrete you would sometimes do it to hard and slam it down a little, thus causing internal damage. the plates i believe would short out on each other and start to discharge.
therefore people linked the concrete with causing the battery to discharge when in fact it was the damage that was caused to the battery while you set it down that made it discharge.
i suppose its possible that the cardboard could dampen the impact enough so no damage is caused internally, so maybe it wasn't completely for nothingI always thought it did.
I guess all that taking out a piece of cardboard was for nothing.
dont worry bro ive been doing it for years and to this day (like yesterday) even though i know its a myth, i still think twice about it when setting them on the garage floor for extended periods //content.invisioncic.com/y282845/emoticons/fro.gif.c695f1f814b01c4ad99fe7f8cccadd29.gifI always thought it did.
