Is anyone here very knowledgeable....
Basically I want to know the difference between my pre-cat and catalytic converter. I have 4 cats on my truck, and I'm just curious about the difference between the 2, if there is any.
pre-cat is just the pipe leading to a catalytic converter, some pre-cat's are built like a resonator to reduce exhaust sound levels. you have so many catalylic converters to help you pass emmisions/smog test. the difference is that a pre-cat pipe is hollow and your catalytic converter has a honey comb type material to fully burn your fuel.
What type of truck do you have? On my Tacoma there are 4 cats. 2 on the exhaust manifold, then O2 sensors, then another 2 cats at which point it squeezes from 2 pipes down to one, out through the muffler. The first 2 are responsible for most of the exhaust clean up, which is why there are O2 sensors after it. The last 2 are only used to clean up a little more w/ no sensors afterwards.
These last cats can be eliminated with no ill effects. However, if this is done, the truck will not pass CA emissions. Anywhere else though, it will pass
Those are useful
Honestly im mindlessly bored at work about 90% of the time. I spend about half my time here and the other half on racingjunk.com //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
Ya I'm just ****ing with you man. I'm at school...//content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
Buck
little alien on campus
Buck
Inside of a pyramid
Buck
