by grounding the block you are grounding the alt....it's mounted to the engine so the easiest way to ground it is wire from the chassis to a mounting bracket bolt
also i couldn't imagine an alternator would put out an increasing amount of current in the 2-4k rpm range...so keeping your rpms that high won't make much of a difference. better alternators will put out higher current at lower rpms
yes that's actually what you are supposed to do. Keep the grounding wire as short as possible, and ground it directly to the chassis just like you would do with the amp.
That would be dependent on the vehicle, if its a unibody no way in hell I would do this. All you are doing is completing the circuit with the run of negitive. You eliminate a few potential problems with grounding back up front.
