is a 2000 mono any good
LGA
is a 2000 watt mono block amp at 1 ohm stable any good for running dual 4 ohm subs
here's a description of the amp
# Mono Block Subwoofer Amplifier
# 1 Ohm Stable
# MOSFET Power Supply
# PWM ( Pulse-Width-Modulation ) System
# Glass Epoxy PCB
# Gold Plated RCA Inputs
# Custom Terminal Block for Speaker Connection
# Thermal / Overload / Short Circuit protection
# Variable Subsonic Filter (15Hz-40Hz, 24dB/ octave )
# Phase Control 0-180 degree
# Remote Bass Boost
# Input Impedance: 10K Ohms
# Soft Turn ON/OFF
# Advanced Protection Circuitry
# S/N Ratio: > 90dB
# Dimensions: 1.97'' H x 11.42'' W x 12''
if it's thier class d amp, then yes. if it's a non class d 2channal amp then it's not that good of quality...i mean itll get the job done but it wont put out 4000w.....thats lanzar for you...but hier vibe class d amps are good and so are the optidrives
he got LEGACY not LANZAR
I was gonna say thats one small *** amp //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif.
don't get the legacy. Won't do close to rated power and prolly won't be around for a month //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
budget?
LGA
LGA
batavia, new york
wilzyx
