iPad+JL Audio CL-RLC+4 channel+mono=??
I have one of those in my car and I don't think it'll work well in your situation. You'll run into the problem of needing y-splitters or two of those things so you can have sub volume control as well as fade.
There's one input and two outputs on that JL piece. One output is a pass thru which cannot be controlled via the knob. The other output is controlled thru the knob.
If you're looking to be able to control F&R fade as well as the subwoofer, this isn't going to do it. I'd look into other processors with outboard sub volume controls as it'll be a line driver with more outputs and control.
04murdalanche
Dallas, Tx/Ada, Ok
04murdalanche
