internal volume with or wihout port section volume?
BassAddictJ
this MAY sound noobish but......when calculating the internal volume of a ported box, is there any relivance to knowing the volume without the port section?? or just measure all internal area for the net volume?
EX. my box is 6.4 cubs total.....internal chamber withthe sub is 4.4cubs and the rest of the area where the port starts to the opening of the port is 2.0cubs. all for my xxx15
just wondering if 4.4cub area had any relavancy or is it just total internal volume that should be counted as the "box's volume".
The internal volume, the 4.4 cubes, is considered the "box size," the rest is the port size. 4.5 cubes I believe is what RE recommends for SQL, so you should be good as far as your box is designed. What is your port tuned to? Should be a good setup
thats also a good question....the box is supposed to be tuned to 34Hz but we had to redisign the box while we built it because we didnt realize the design was for a 12 until we had to cut the wood. either way.......it should be good....
So when a manufactor recommends 3.25 cu. ft. for a ported box, they're not including the port volume?
Yup!
When calculation box volume...NET volume is what is given. NET box volume is the INTERNAL volume AFTER port displacement, sub displacment, etc. Remember when calculating port volume to account for the .75" of MDF that is also part of the port //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
NG
BassAddictJ
BassAddictJ
FL
Mr. Loki
michigan born
    May 14, 2026
michigan born
    May 14, 2026
