Interfire EF-700 vs Clarion EQS746 EQ
  • 4
Gain isnt a volume knob.
agreed but when i set my gains with a multimeter and cant get them were they need to be there is two issues either my amp or HU when i turn the level on my subwoofer setting up on the HU i get the voltage i need at the meter but i would rather leave it flat so at that point i am assuming it is a signal issue from my HU. my previous HU had 4 volt preouts and i was able to set my gains no problem with a meter.
What headunit is it?
If it's a subwoofer level and not a general "bass" setting that is how it's supposed to operate. You get more voltage from the pre-outs by turning the level up. The issue here is in your head, not that you have an equipment problem. 2V pre-outs is enough for your amplifier.
Thanks that makes sense and I kind of figured that I have just always seen that debate on pre out voltage and there is a lot of mixed opinions on the subject. I messed with it yesterday and I noticed that when i wiggled the RCA inputs on my amp (AQ2200) the voltage on the meter would spike from 14-18 volts up to 28 volts and that is with the gain set a little over 3/4 so it may be a issue with the inputs on my amp.
if so bryant ,i know where you can get it looked at locally and fixed if needed
  • Locked
Additional photos, videos, or live feed available on request.
Looks similar to this: https://www.sonicelectronix.com/item-17681-Clarion-CX609.html I'd call Sonic Electronics and see if they have what you...
Thats its manual fore using, not Tecnical.expaining , have pinted out service manual., and the cable i think was fore swc,its made fore satelite...
I dont think anyone can answer that question of if a BTooth adapter will sound as good as a CD? Only one would know by actually using the same...
948
I would recommend to get on F.Book @ Old School Stereo and run a Want To Buy thread there. Im sure someone is hoarding one, maybe even a BNIB one...
Superchevyman
Superchevyman
Salinas CA
mylows10
    May 12, 2024
Brendon Jenness
    May 11, 2024
