Interesting issue with polk comps and a kicker ZX amp
Super, on post #12 you mention that both amps are grounded to the battery ? You are supposed to "ground" the amps to the vehicle's chassis, not to the battery. Since you have two amplifiers, I suggest you get a fused distribution block. You will have a red wire thats connected to your battery's positive terminal. That wire(usually a 4 gauge size) is connected to one side of the distribution block and then you will have two wires coming out of the distibution block that will connect to the amplifier's positive connection. Also, I'm not really sure what the total wattage of both amps is that are being used, but I suggest you purchase an Optima Yellow Top battery and mount it in the back of your vehicle, you will need an battery isolator for that. Also you need to get a 1 Farad capacitor, it's recommended 1 Farad for every 1000 watts of power you are using. They do make .5 or 1/2 Farad capacitors, that would be for for every 500 watts one 1/2 Farad capacitor is recommended. Also an aftermarket high output alternator would be great. Without those items your vehicle's electrical system is being "overkilled". A rule of thumb is your headlights should not dim while you are playing your sound system. Remember, when the manufacturer designed the vehicle, they did not calculate a sound system in the electrical system.
Here are some websites for the things you need, Good Luck:
Stinger battery isolator:
http://www.hifisoundconnection.com/Shop/Control/fp/scat/39420/SFV/30046
Fused Distribution Block:
http://www.streetwires.com/products/fusedDistBlock/positiveDistBlocks.cfm
Ground Terminal(from the negative connection of you amp to the vehicle's chassis):
http://www.streetwires.com/products/groundTerminals/
1 Farad Capacitor(s):
http://www.streetwires.com/products/powerStationCaps/index.cfm
Stinger high output alternator:
http://www.stingerelectronics.com/prodDetail.asp?strID=47
Optima YellowTop battery:
http://www.optimabatteries.com/publish/optima/americas0/en/config/product_info/automotive.html
Just in case( I got this from a website in geocities):
How does a Battery Isolator work?
It's an electronic sealed unit that contains two diodes.
Diodes permit current to flow in one direction only. Power supplied to the middle stud of the Battery Isolator flows to each of the other studs. Current cannot flow back from one of the batteries to the other battery. Charging current flows preferentially into the battery with the lowest charge (because of the higher potential difference).
Because they're solid state, isolators have a long life. They're not susceptible to contaminants, vibration, or extremes in temperature.
Supergumby5000
Project: F350 begins...
Supergumby5000
Pullman, WA
Supergumby5000
