Interconnects
SQ Monte
SQ>SPL
I just got my P880PRS today so now i'm really getting down and purchasing all the things i'm gonna need to install the system in my sig. I already have the interior speakers installed so when I install the head unit I am going to run all the wiring so when the amps and subs arrive, it's plug and play. That being said, I have chosen to go with all Stinger interconnects/wiring and accessories. I'll be using the Stinger HPM series amp wiring kit
http://images.cardomain.net/products/sti/STISBT17_2.jpg
Stinger Bullet series RCA's (3 pair)
Stinger HPM series Power distribution block
I'll also be buying some extra power and ground wire that match the amp kit so I can the Big 3 and complete the install of both of my amps, as well as buying some HPM series wire terminals.
Is there any reason I should not use these products? If so, what would you suggest that won't break the bank?
Same RCAs that I use. I went with the Expert series for the fuse, distro and batery terminals and Audiopipe for the wire. I didn't like the blue of the HPM stuff and I got the Audiopipe cheap.
Cool. I like the blue of the Stinger kit, plus it'll tie in beautifully with the rest of the system considering the P880PRS lights up blue(and white if you so choose), the logos on both the amps also light up blue, and the led's on my flush mount head unit install kit are blue!!! I almost went for the Helix series RCA's for my 4ch amp cause they have a 4ch interconnect, but the red would just throw everything off so Bullet series it is.
SQ Monte
SQ>SPL
SQ Monte
Sacramento
helotaxi
