interchangeable bass knob
Most of the time no. They won't change over. While they may plug in and may even look the same, look at the pins/wire and you will see some are flipped while others are not.
Most of the Korean based amps can use the same knob, but I see zero reason to use them myself. We do everything we can not to install them, even in clients cars.
Local shop won't install them, period. They will[/b] give you the ones out of the boxes from the amps for you to install yourself if you beg them enough, but they advocate severely against. They let me do it because they know I only use it for a cut.
I use cheap amps, not good amps
fixed
That is because of the lack of ability to control what some kid will do with it. That and most think it is just another "volume knob" that can be turned as far to the right as possible.
I use a remote gain knob, not a bass knob sir
One in the same on some amps. Called the latter, is actually the former.
---------- Post added at 10:19 AM ---------- Previous post was at 10:18 AM ----------
If you set the gain with it disconnected, typically they can turn it as far right as they wish.
//content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
---------- Post added at 10:19 AM ---------- Previous post was at 10:19 AM ----------
if i'm listening to rock i like to have the ease of being able to turn the bass down without going through the headunit
and why are you turning down the bass on rock?
BoomBoxStereo
@woofergram
BoomBoxStereo
Long Island, NY
BoomBoxStereo
