Interchangable Enclosure?
MAkahveli
I found a nice bandpass alpine type S 10" subwoofer enclosure box on ebay local for only $10 and a perfect match for my trunk. the box is 13*x13'x26 1/2". The thing is that I have an Eclipse 10" Aluminum sw810? but anyways according to the enclosure calculators Ive used the enclosure measurements are what I would need for a sealed box. Now is it a bad idea to turn this bandpass box into a sealed enclosure? It has only one port and that would be where I would cut the hole for my sub. Or should I just try to run it bandpass?
I also wanted to know, does bandpass enclosure shorten the life of your sub, since your sub is working against trapped air?
if this was the case then running subs in sealed boxes would also shorten the subs life.......
I was asking, not making a statement. What makes a subwoofer heat-up?
But anyways nobody answered my question, would this work if I converted the enclosure to sealed?--its already at the dimensions I need, it will be in my trunk and not for show.
um dude, if you dont have the ability\tools\materials\money\time for a custom box for your sub, and this box is the correct size for it and you can modify it to a sealed box, go for it.
its $10
i say expierement. why not //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
MAkahveli
MAkahveli
Denver, CO
req
Mike Mccabe
