Mills561
BURR
How would you go about doing this? I am going to be installing two amps-one for lows, one for highs. Right now I already have the high amp hooked up, but the power wire is connected to the fuse box under the hood... I was unaware of this at the time of installation, I didn't install it, but everything I've read says I need to connect it to the battery. Is this correct?
But besides that, how would you connect two amps to one battery without a distro block? Would you run one wire and use a wire splitter (essentially a distro block...), or two separate power wires? Thanks for any replies.
