How do you feel about some of the car audio companys takes on pro? Crescendo etc
Honestly never tried them. My theory anyway is, they aren't dong anything special. They are taking advantage of the fact that some guys like to run pro audio, and most of those guys they are catering to run cheapo speakers to begin with. I'm also fairly confident most of those companies just sell rebadged pro audio anyway, and then jack the price up. I know if I wanted to make a car audio line, that's how I'd do it. Your not going to make a speaker for cheaper than Pyle or Eminence, they have too much production volume.
So I stick straight to the source where I know I can get a quality product as they are used in professional apps at the highest level. They have larger coils that handle power better than car audio speakers, just as rugged, or even moreso on build quality, very high effeciency and at the top level, SQ is a paramount concern so you have well dampened cones all things considered, shorting rings and linear motors. They generally sell in bulk so prices aren't inflated like most car audio speakers. For 300 dollars you can pretty much get any top line pro audio mid available, so 600 and you have the best... How much for a top of the line morel mid nowadays? Even sadder I know Vasyachkin measured the T/S of alot of Morels stuff a few years back and EVERYTHING was way off spec, even from driver to driver, so terrible consistency. Again, only in car audio would a manufacturer like that be considered high end.. ****, go look at their Ultimo pricing, that's insane for no reason.
12mm xmax, a 5" coil that only handles 1000 watts for $1000.. Only saving grace is they seem to use a shorting ring since inducatance is fairly low. To put it into perspective, my 21 costs around the same, about 100-150 less on average if you get a smaller size like a 15, it's a about half, lol. All models have similar inductance DESPITE having a bigger VC, (6inches), 25% more xmax, alot more abuse resistant oh and did I mention double the RMS rating? How many ultimos would you need to match my B&C, probably close to 4, that's what 4 grand in speakers to do match it for less than 1000. Only downside is the supension isn't ultra quiet on my B&C, but unless your invert mounting, it's a complete non-issue. Inductance is lower on the morel, but unless your crossing over 200hz, it's a non issue.
