Installing Speakers in headrest. Need Help!
OP I'd get rid of all the stuff you have and do 2 6.5 or 8" PA mids per door and 1 supertweeter. That will easily keep up with your substage and if set up properly; not overpowered and a little tuning/EQ work they will sound very good.
I second this. you dont need to do all those speakers in the rear deck
Thanks, I got a 2 year old son, a daughter on the way and we're preparing to move back down south to Dallas. So at the moment I'm not inclined to get rid of everything and start over. I'll do it eventually though.
I'll keep the 6X9s in the rear deck and stick 1 6.5 on each door. That still leaves me with some place to put the 3"s. I was thinking about putting them in the front door as well, but I was also considering the middle console. Do you have any experience with that?
Off topic. My subs' displacement is .23. Now I know that I need to subtract that from the enclosure volume, however does the displacement change when you're using a double panel face? (Using 3/4 MDF)
It doesn't? I just found out the displacement of my panel if it were a single piece is .33 Well I have a 2 layer panel. Why wouldn't I subtract that as well? Total of .66 displacement for double panel.
Technically, if you have to build into your airspace to do a double baffle then yes, it will affect the volume.
Yeah because by it being double paneled that's less sub being applied to the internal space of the enclosure.
jkok7
jkok7
Dallas, TX
jkok7
Mike Mccabe
