Installing an Alarm???
carguy6702
how hard is it to install and alarm? i want to install one in my 2001 GMC Sierra its the base model no power windows or locks. i also want to install power locks and power windows. what tools would i need and what equipment? can anyone help on how to install? thanx
Here is the wiring diagram. You will need some crimps,test light,connectors,etc.
12volts red + ignition harness
Starter yellow + ignition harness
Ignition pink + ignition harness
Power Lock lt. blue + brown plug at BCM
Notes: The BCM is located behind the drivers side of the dash. The plugs on the BCM face towards the rear of the vehicle. The parking lights are in pin A5 and the headlights are in pin A11.
Power Unlock white + brown plug at BCM
Lock Motor gray driver kick panel
Unlock Motor tan driver kick panel
Disarm Defeat tan/black passenger kick panel
Parking Lights+ brown + lt. blue plug at BCM
Parking Lights- white - lt. blue plug at BCM
Hazards
Turn Signal(L)
Turn Signal®
Door Trigger - BCM
Use tan for the drivers door located in pin B4 of the purple plug, and for the passenger door it will be a orange in pin B2 in the purple plug or dk.blue/white in pin B11 of the lt.blue plug, must diode isolate these wires.
Dome Supervision
Trunk/Hatch Pin
Hood Pin
Trunk/Hatch Release
Power Sliding Door
Factory Alarm Arm
Factory Alarm Disarm lt. green - driver kick panel
Notes: Also found in the purple plug of the BCM.
Disarm No Unlock
Tachometer white ac ECM
Notes: ECM is located near the battery, down low, between the fender and the fan under the black plastic cover. On the 4.3L, the tach wire is at pin 20 in the connector labeled red. On the 4.8L, 5.3L, and 6.0L, the tach wire is located at pin 10 in the red connector.
Diesel tach wire is white at the cluster.
Horn Trigger black - brown plug at BCM
Memory Seat 1
Memory Seat 2
Memory Seat 3
Interface Module: Category:
Immobilizer Bypass Required:
Yes Type:
Passlock II
Part #: 556LW
Alternate Part1 #: 555LW
Alternate Part2 #: DesignTech 20402
Alternate Part3 #: DesignTech 29402
Notes:
Door Lock Interface Required:
No Type:
N/A
Part #: N/A
Notes:
Combo Interface Required:
Yes Type:
Data Bus
Part #: 457GW
Notes: Can use the 457GW to bypass the Passlock II, but it will not control the door locks on this model year.
carguy6702
carguy6702
Dallas, Tx.
eatank
