installing a digital volt meter ??
I would wire them to what you want to see. If you want the battery's voltage then go to the battery. I dont think the alt will tell you anything. Personally I go to the amps. It is the last thing in the electrical chain before the subs. Gives me an a voltage reading that is equal to the voltage entering the amp from the battery.
SO if your bi amping, Can you just pull out one of the amps power/ grounds. Run the volt meters power/ground to the amps power/ground and then reattach them to the amp? Would that give you accurate reading for both amps?
like this. All grounds go to correct places, i just didnt want to draw it.
big scott
blazin low, and loud
big scott
edgewood, md
adulbrich
BP1Fanatic
BP1Fanatic
