installing 6.5" comp set.. what do i need?
Yes you will need to fabricate a ring from MDF, ensure that you choose a thickness that allows you to clear all door internals. There are prefab mounting plates you can buy made from ABS but I hate these.IMHO Its always a good idea to do some sound deadning.
General-Wire, a way and place to mount x-overs. Have fun don't worry if you make 4 or 5 sets of mounting rings its all learning.
He will only need a dremel or something like it if mounting it directly to the door and that is not a guaranteed thing. With the MDF ring you should not need it.IMHO
Was it 6x8 or 4x6. The cone is the widest portion even if its 61/2 in a 6x8 hole, using a 1/2 MDF ring that sounds wierd. Unless your speaker basket is even with the cone all the way down or is wider than the cone surface or lip. I have also put 6 1/2 in an 6x8 hole and never trimmed the door.
While most Asian and African markets will identify Honda's small hatchback as the Jazz model, most Western regions will know the same model as the...
101
There are a couple that SMD has tested, around $20.00 that should take the wattage from most any HU. If you are tapping into the speaker wires...
hittin it
hittin it
Marion County
genxx
    May 12, 2024
Brendon Jenness
    May 11, 2024
